I am learning how to use the VIP suite on a cyclone III C25 board. I put a memory interface (flash, ssram... which is working), a oc_i2c_master, a test generator pattern and a clocked video output. I managed to compile the project but I don't have anything in output. I chose : Active pixels : 800 Active lines : 600 Pixel fifo size : 800 H sync : 80 H front porch : 16 H back porch : 160 V sync : 3 V front porch : 2 V back porch : 21 For the test generator pattern, I chose : Max image width : 800 Max image height : 600 RGB, color plane configuration in parallel, progressive output, color bars Do someone has an idea ? If you need more details, just ask me. Thanks, MyriamLink Copied
