21610 Discussions
Easy nios design with buttons
I am a newbie with Quartus II and Nios II and I have been trying to do an easy nios design in order to light on a led when pressing a button. I am working on the Altera Cyclone III EP3C25F324 board. I think the problem comes from my code in nios II that I put below. I don't really know when to write "IOWR_ALTERA_AVALON_PIO_DATA(...);" maybe the problem comes from here. Plus, when I try to write some "printf", there is an error :
collect2: ld returned 1 exit status
make: *** [button_led.elf] Error 1
Here is my program :
#include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "stdio.h"# include "stdlib.h"
int alt_main (void)
alt_u8 led = 0x2;
alt_u8 button = 0x2;
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, led);
IOWR_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE, button);
while (1)
switch (button) {
case 0x1 :
led=0x1;
break;
case 0x2 :
led=0x2;
break;
case 0x4 :
led=0x4;
break;
case 0x8 :
led=0x8;
break;
Do someone can help me?
Thank you very much,
Myriam
try this:
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "stdio.h"# include "stdlib.h"
int alt_main (void){
while(1){
button = IORD_ALTERA_AVALON_PIO_DATA(BUTTON_PIO_BASE);
IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, button);
It lights on the 4 leds without any change when I press a button.
Maybe it comes from my quartus II design ?
I would double check the pin connections of the buttons . A good tip is to use signal tap to see if anything happens on those pins.
//Bango
I am trying your idea but it is the first time I am unsing the tap signal interface and I am not succeeding. I read the literature on Altera but I still don't understand my mistakes. First, a word about my design. I added to the CIII_NiosII_Small design provided by Altera a BUTTON[3..0] signal as another entry. On the SignalTap II Embedded Logic Analyzer, I added the four signal (corresponding to each button), the clock and entered the hardware setup (USB).
Now I have errors from the Analyzer :
ISED_PROGRAM_DEVICE CAUSE: You attempted to run the SignalTap II Logic Analyzer, but the current design does not match the design programmed in the device. ACTION: Program the device with the current design, and re-attempt to run the run the SignalTap II Logic Analyzer.
And from Quartus :
Error: Current license file does not support incremental compilation
Can you help me ?
1. Check your pin assignments.
2. Verify that your base addresses for PIOS in SOPC are same that ones in "system.h".
I've been doing some other stuff and I am now back to my button design.
I checked my pin assignments (they are fine) and my base addresses for PIOS in SOPC and the ones in "system.h" matches.
I tried the easy program below and when I press the button, nothing happens. It seems that there is still another connection problem but I don't know which one.
int alt_main (void)
while(1){
button = IORD_ALTERA_AVALON_PIO_DATA(PIO_0_BASE);
if (button==0x01)
printf("button 1");
return 0;
Thanks for your patience,
Myriam
Maybe it's the problem of alt_main(), unlike main(), some driver initialization should be added manually.
# include "sys/alt_sys_init.h"
in alt_main():
alt_sys_init();
alt_io_redirect (ALT_STDOUT, ALT_STDIN, ALT_STDERR);
I haven't checked myself it yet. but you could try using main() instead if you have enough RAM
Yue
