Is it possible to embed SDC constraints ourself using verilog HDL source code? If yes, can someone tell me how to do?
I believe you use a Verilog attribute statement ...
(* ALTERA_ATTRIBUTE = “-name SDC_STATEMENT set_multicycle_path -end -setup -from -to [get_registers *|REG2)
Jake
Thanks for your quick reply....This is exactly what I want....
is it somehow possible to attach a timing contraint to a reg definition?
I've found this:reg q2;
// Equivalent to set_instance_assignment -name CUT ON -from q1 -to q2
(* altera_attribute = "-name CUT ON -to q2" *) reg q1;
on: quartushelp.altera.com/10.0/mergedProjects/hdl/vlog/vlog_file_dir_attribute.htm but I believe that's only working with classic timing analyser. is there something an equivalent for timequest??
