From the datasheet...
SS: A soft-start capacitor is connected between this pin to AGND. The value of the capacitor controls the soft-start interval and startup time.- Mark as New
--- Quote Start --- From the datasheet... SS: A soft-start capacitor is connected between this pin to AGND. The value of the capacitor controls the soft-start interval and startup time. --- Quote End --- What happens when i connect SS directly to GND?
It starts so softly that you never see a voltage at the output.
--- Quote Start --- It starts so softly that you never see a voltage at the output. --- Quote End --- I have manufactured the pcb, so when i disconnect the SS and leave it no connect, can i see the voltage then? I am trying to know if a rework on pcb is worth it. Thanks
Try it and see.
--- Quote Start --- Try it and see. --- Quote End --- Today i will try ( leave Ss pin unconnected) and tell the results. You know its so hard to make that pin unconnected due to the package but i will try it with a technician.
Topic Options
