21611 Discussions
Enable DEV_CLRn in MAX-V
Hi, I would like to enable DEV_CLRn on pin 29 in order to do a device clear. However, it seems to be set to user I/O whenever I enable the pin in Quartus. How can I set the pin to be DEV_CLRn? Thanks.
Hi sallo_93,
In the Quartus go to Assignment menu --> Device --> Device and Pin Options --> General then choose the “Enable device-wide reset (DEV_CLRn)” check box. This will enable the DEV_CLRn pin. Then recompile the project design.
nyusof
(This message was posted on behalf of Intel Corporation)
Hi nyusof, figured it out. Thanks anyway!
Altera should probably consider implementing this assignment option in Pin Planner to make it more visible.
