Programmable Devices
21611 Discussions
Error (10170): Verilog HDL syntax error at CMD_FSM3.sv(109) near text "~&"; expectin
hi all,
i'm trying to write FSM that check few commands out of about 10 available command and i get this error message when trying to use nand with if can you please tell me what do i do wrong?
else if ((!data_in_valid)~&(data_in==GET_CONFIGURATION)) invalid_cmd<=1;
GET_CONFIGURATION is a parameter, data_in and data_in valid are logic inputs
Eli
~& is not a valid operator in Verilog. For a NAND, you should write it as:
(~((!data_in_valid) && (data_in==GET_CONFIGURATION)))
or
(~((!data_in_valid) & (data_in==GET_CONFIGURATION)))
In this case a long as data_in_valid is a single bit expression both will give the same answer.
Pete
--- Quote Start ---
or
Pete
--- Quote End ---
Thank you Pete!
