hi all,
i'm trying to write FSM that check few commands out of about 10 available command and i get this error message when trying to use nand with if can you please tell me what do i do wrong? else if ((!data_in_valid)~&(data_in==GET_CONFIGURATION)) invalid_cmd<=1; GET_CONFIGURATION is a parameter, data_in and data_in valid are logic inputs Regards, EliLink Copied
~& is not a valid operator in Verilog. For a NAND, you should write it as:
(~((!data_in_valid) && (data_in==GET_CONFIGURATION))) or (~((!data_in_valid) & (data_in==GET_CONFIGURATION))) In this case a long as data_in_valid is a single bit expression both will give the same answer. Pete- Mark as New
--- Quote Start --- ~& is not a valid operator in Verilog. For a NAND, you should write it as: (~((!data_in_valid) && (data_in==GET_CONFIGURATION))) or (~((!data_in_valid) & (data_in==GET_CONFIGURATION))) In this case a long as data_in_valid is a single bit expression both will give the same answer. Pete --- Quote End --- Thank you Pete!
