Error 10200
Hi Everyone,
When trying to synthesize the following code I get the error:
Error (10200): Verilog HDL Conditional Statement error at prog_counter.v(62): cannot match operand(s) in the condition to the corresponding edges in the enclosing event control of the always construct
The code is from the book Verilog Coding for Logic Synthesis by Weng Lee (Ch. 6)
What generally causes this type of error?
Here is the code with the problem line indicated
always @(ceb or write or reset or load or data_in) begin if (~ceb & write & ~load & ~reset & ~flag_counter) control_word_register = data_in ; else if (~ceb & ~write & load & ~reset & ~flag_counter) latch_counter = data_in; else if (ceb & ~reset) begin //reset the control word counter control_word_register = 0; //reset the latch latch_counter = 0; end else if (disable_CWR) control_word_register = 0; end //to counter for counter always @(posedge clk or posedge reset or posedge trigger) begin if(reset) begin disable_CWR <= 0; flag_counter <= 0; counter <= 0; flag_half_counter<=0; end else begin >>Error << if(control_word_register) //counter is enabled << *****Error 10200 Here****** begin if(control_word_register == 2'b00) //this if for one shot mode begin if(~flag_counter) begin counter <= latch_counter; flag_counter <=1; end else begin if(counter == 8'hff) begin //to stop counter for one shot mode disable_CWR <= 1; flag_counter <=0; end else counter <= counter + 1; end end else if (control_word_register == 2'b01) //waveform generator mode begin if(~flag_counter) begin counter <= latch_counter; flag_counter <= 1; end else begin if(counter == 8'hff) flag_counter <= 0; counter <= counter + 1; end end else if(control_word_register == 2'b10) //this if for the 5-% duty cycle waveform generator begin if(~flag_counter) begin counter <= latch_counter; flag_counter <= 1; end else begin if (counter == {1'b0,latch_counter}) begin flag_half_counter <= ~flag_half_counter; counter <= counter - 1; end else if (counter == 0) flag_counter <= 0; else counter <= counter - 1; end end else if(control_word_register == 2'b11)//this is for triggered pulse generator mode begin if(~flag_counter) begin //If we aren't currently sending out a pulse, then keep the counter loaded and ready //this also resets the counter after a successful pulse is generated so that we will be ready for the next trigger counter <= latch_counter; if(trigger) flag_counter <= 1; else flag_counter <= 0; end else if(counter == 8'hff) begin //stop counter for triggered pulse mode flag_counter <= 0; end else counter <= counter + 1; end end end end
The Problem appears in the second always block on the line
Any input on this is really appreciated...
Figured it out, it was the fact that the second always block was sensitive to the trigger. I removed it from the event list and just sync the trigger to the clock before it reaches this module.
Thank you, I had the same problem. Worked for me too.
