I've finished creating the NIOS II processor system without errors. During integrating the system into Quartus II project I've got an error (10500): VHDL syntax error at CHKMNG_inst.vhd(2) near text "CHKMNG_inst"; expecting "entity", or "architecture", or "use", or "library", or "package", or "configuration". But in Altera's examples files *_inst.vhd have the same syntax! How to fix this problem?
Thanking you in anticipation.Link Copied
Could you put the CHKMNG_inst.vhd file please.
--Example instantiation for system 'CHKMNG'
CHKMNG_inst : CHKMNG port map( out_port_from_the_ACHK => out_port_from_the_ACHK, out_port_from_the_CTR0HEX => out_port_from_the_CTR0HEX, out_port_from_the_CTR1HEX => out_port_from_the_CTR1HEX, out_port_from_the_CTR2HEX => out_port_from_the_CTR2HEX, out_port_from_the_CTR3HEX => out_port_from_the_CTR3HEX, out_port_from_the_ERR => out_port_from_the_ERR, out_port_from_the_PASS => out_port_from_the_PASS, out_port_from_the_PMARK => out_port_from_the_PMARK, out_port_from_the_RST => out_port_from_the_RST, out_port_from_the_WCHK => out_port_from_the_WCHK, clk_0 => clk_0, in_port_to_the_KEY => in_port_to_the_KEY, in_port_to_the_RSIN => in_port_to_the_RSIN, in_port_to_the_RSVAL => in_port_to_the_RSVAL, reset_n => reset_n );- Mark as New
The problem is not here but before, because Quartus expects something else than CHKMNG_inst.
So can you put all the code before also please.- Mark as New
It's a whole file. There is nothing else in it. SOPC Builder generated it automatically.
But this file is just an example. To instantiate this component, you use the same code but with your input/output signals.
This file should not be integrated in a Quartus II project. If it is not clear ask any question.- Mark as New
I removed file CHKMNG_inst.vhd from the list of project files and problem disappeared. Thank you very much!
