Programmable Devices
20764 Discussions
Error (10819)
Hello.
I want to generate a simple square wave with the system clock at 135 MHz.
The "rechteck_out" vector is interpreted as "Signed(Two's complement)".
I get the following error message after compiling:
Error (10819): Netlist error at rechteck.vhd(25): can't infer register for rechteck_out[16] because it changes value on both rising and falling edges of the clock.
This is my vhdl-code:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
use ieee.std_logic_unsigned.all;
ENTITY rechteck IS
PORT(
clk : IN STD_LOGIC;
rechteck_out : OUT STD_LOGIC_VECTOR(20 DOWNTO 0)
END rechteck;
ARCHITECTURE behavior OF rechteck IS
BEGIN
PROCESS(clk)
BEGIN
IF (clk'event and clk = '1') THEN
rechteck_out <= "100000000000000000000";
ELSIF (clk'event and clk = '0') THEN
rechteck_out <= "011111111111111111111";
END IF;
END PROCESS;
END behavior;
Could you please help me to solve this problem...
May be I will be alive the day when flips can work on both edges of its clk.
You can't do that yet.
A physical register (flip-flop) has a single clock input. The flip-flop only latches data on a single clock edge. You cannot do double-edged clocking.
Jake
Hello tobias,
as always Gurus are right ( otherwise they would not be gurus :) )... no way to get a F\F triggering on both clock edges... such a shame...
If you have a 135MHz clock input you can generate a 67,5 MHz squarewave feeding the D input with the inverted Q output of a F\F and clocking it @ 135MHz.
If you really need a 135MHz squarewave ( that is the reproduction of the input clock btw ) you can either buffer it, or feeding a PLL macrofunction IN pin with it and set a 1\1 input\output ratio, or feeding a PLL macrofunction IN pin with it and set a 1\2 input\output ratio and feeding the OUT to clock a F\F arranged as before, or ... etc. etc.
I can go on with examples but I assume the concept is clear :)
