Programmable Devices
21597 Diskussionen
Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system.
NMene
Einsteiger
1.258Aufrufe
I am having the problem above, my board is the DE10 Standard and I am following all the steps on chapter 8.3 of the user manual.
When I program the cyclone V with a SOF file, it does work. I couldn't find a good explain of MSEL DIP in any manual also.
Would you please help me?
Thanks in advance.
2 Antworten
AnandRaj_S_Intel
Mitarbeiter
835Aufrufe
Hi NMene,
Can you please check your MSEL again.
Set MSEL[4..0] = “10010”
It should be like.
SW10.1 MSEL0 ON (“0”)
SW10.2 MSEL1 OFF (“1”)
SW10.3 MSEL2 ON (“0”)
SW10.4 MSEL3 ON (“0”)
SW10.5 MSEL4 OFF (“1”)
SW10.6 N/A N/A
Reference table 7-2.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Anand Raj Shankar
NMene
Einsteiger
835Aufrufe
Ok, Now everything is working fine. Thank you very much. Nilton Gaviao Menezes. Em dom, 17 de fev de 2019 às 22:32, Intel Forums <supportreplies@intel.com> escreveu:
Antworten
