Programmable Devices
21608 Discussions
Error: Cannot find source node 'ddr2_dqs[0]_in' -- help me DDR2 in sopc
hi, i am getinng this error, i also included design file.
regards,
baba
Info: Running Quartus II Shell
Info: Version 7.1 Build 156 04/30/2007 SJ Full Version
Info: Processing started: Fri Oct 05 11:00:21 2007
Info: Command: quartus_sh -t auto_verify_ddr_timing.tcl compile DDR2_TEST DDR2_TEST
Info: Quartus(args): compile DDR2_TEST DDR2_TEST
Info:
Info: =======================================================
Info: == DDR/DDR2-SDRAM Megacore v3.4.1 In-System Timing Verification
Info:
Info: Verifying in-system timing for DDR/DDR2-SDRAM Megacore variation 'ddr2'
Info:
Info: Running Quartus II Timing Analyzer (delay extraction only)
Info: See file 'ddr2_extraction_log.txt' for detailed log messages
Extra Info: Found a clock output pin: NIOS_DDR2_CK_P0
Extra Info: Found a clock output pin: NIOS_DDR2_CK_N0
Info: The most likely cause of this type of error is:
Info: (1) Some signals on the local-side interface are not connected causing logic to be optimised away,
Info: This script requires that the complete logic for the specified width of the datapath (both read and write paths) be present in the design.
Info: (2) The clear-text HDL files for the datapath may have been modified.
Info: (3) Not all clocks from the system pll are global.
Error: Extractions stopped due to error
Info: Skipping DDR system timing analysis equations.
Error: In-System timing verification of DDR/DDR2-SDRAM Megacore variation 'ddr2' could not be completed due to the above errors.
Error: Evaluation of Tcl script auto_verify_ddr_timing.tcl unsuccessful
Error: Quartus II Shell was unsuccessful. 4 errors, 0 warnings
Info: Allocated 50 megabytes of memory during processing
Error: Processing ended: Fri Oct 05 11:00:50 2007
Error: Elapsed time: 00:00:29
Error: Quartus II Full Compilation was unsuccessful. 4 errors, 287 warnings
Looks like you are using a very old version of the DDR2 compiler. 3.4.1
You are using Quartus 7.1, so you should be using DDR2 megacore version 7.1 too.
In fact Quartus 7.2 was released a few days ago.
try this and see how you get on.
Hello, were you able to solve this problem? I'm getting the same error message and I am using the lastest Quartus version and service pack. I'm using the Free IP Base Suite that has the DDR2 Megacore function. Please let me know if you solved the problem because I've been working on this problem for some time.
joe
I received an error similar to this and it was a result of the first situation. For me, I was instantiating a tester around the interface, so I'd insert data and read back data. The problem with that is that Quartus will end up "optimizing" away some of your connections, not knowing that they are actually important. The way I got rid of the errors was to place output pins on each of the connections, thereby telling Quartus that the connections were important and not to "optimize" them away.
Not sure if this will fix your problem, but it worked on mine. Only took me a week to figure out. :(
