I have a verilog code working with multiple files. I use synopsys library DW01_addsub, DW02_mult, DW01_add, DW01_sub and DW03_pipe_reg so that the resource can be optimal.
When I tried to start Alalysis & Elaboration (Quartus II version 10.1), there are many errors: Error: Node instance "U1" instantiates undefined entity "DW01_addsub" Error: Node instance "mult" instantiates undefined entity "DW02_mult" Error: Node instance "add" instantiates undefined entity "DW01_add" Error: Node instance "sub" instantiates undefined entity "DW01_sub" Error: Node instance "U1" instantiates undefined entity "DW03_pipe_reg" I think there might be because of no link (path) to the synopsys library DW, is it right? How to link with the synopsys library?Link Copied
Yes that the problem. If you have the verilog/vhdl source for the library elements you add them through assignment->settings->Libraries
Pete- Mark as New
I provide this path "c:/altera/10.1/quartus/eda/synopsys/dw/lib" in both Global Libraries and Project Libraries. It is still show the errors.
Did I provide the right path? or any other ideas?
