Programmable Devices
21602 Discussions
Error in GDB server launch sequence
zumair
Hi all,
I followed the available resources to test NiosV by running a simple "Hello World" application. Everything seems fine until the last step, where in Ashling RiscFree IDE, I try to run my application, but it shows an error: "Error in GDB server launch sequence". Also i have attached images of the timing violations i face after compilation. Could the issue be related to that? Any suggestions or help would be appreciated. Thank you in advance!
Board: Arria 10 GX FPGA Development Kit (part number: 10AX115S2F45I1SG)
SW Ver: Quartus Prime Pro 24.1, RiscFree™ IDE for Intel FPGAs v24.1.1
Farabi
"We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum cases, along with others, did not get through as intended. As a result, we have a backlog of cases that we are currently working through one by one.
Please be assured that we are doing everything we can to resolve this issue as quickly as possible. However, this process will take some time, and we kindly ask for your patience and understanding during this period. The cases will be attended by AE shortly.
We appreciate your patience and understanding, and we are committed to providing you with the best support possible.
Thank you for your understanding."
JingyangTeh_Altera
Hi
Did you create your project with Quartus 24.1?
If not could you try migrating your project to Quartus 24.1.
Jingyang, Teh
JingyangTeh_Altera
Hi
Do you have any follow up question on this?
Jingyang, Teh
JingyangTeh_Altera
Hi
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
