21602 Discussions
Error with Ethernet Design
I followed the instruction from the course "10/100/1000 Mb Ethernet Design with Altera Transceiver Devices: Introduction (OTSE1116)", and I got this error:
Error: System.altera_ethernet_1: altera_ethernet_1.receive and eth_mon_inst_1.avalon_streaming_sink must be on the same clock domain, since they're connected.
Can anyone tell me how to fix it? :D
Yes, connect both clock inputs to the same clock.
Yeah, I changed the clock and that worked. Now I got these errors:
Error: The design contains 2 blocks of type "Embedded multiplier block" but the selected device EP4CGX15BF14C8 does not support such blocks Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_1|mult_add_gkr2:auto_generated|ded_mult_e091:ded_mult1|mac_mult2. Implement the design block using soft logic by choosing the relevant option in the related megafunction Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_2|mult_add_ikr2:auto_generated|ded_mult_e091:ded_mult1|mac_mult2. Implement the design block using soft logic by choosing the relevant option in the related megafunction Error: The design contains 2 blocks of type "Embedded multiplier output" but the selected device EP4CGX15BF14C8 does not support such blocks Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_1|mult_add_gkr2:auto_generated|ded_mult_e091:ded_mult1|mac_out3. Implement the design block using soft logic by choosing the relevant option in the related megafunction Info: Node name: tse_ref_design:tse_ref_design_inst|tse_ref_design_cpu:cpu|tse_ref_design_cpu_mult_cell:the_tse_ref_design_cpu_mult_cell|altmult_add:the_altmult_add_part_2|mult_add_ikr2:auto_generated|ded_mult_e091:ded_mult1|mac_out3. Implement the design block using soft logic by choosing the relevant option in the related megafunction
I guess the original project made for Stratix IV, but I changed the device setting to Cyclone IV in Qsys and Quartus. I am not sure if it is the reason for these errors, and I don't know how to fix. :D
Recreate the project from begining only using this project as reference.
open up the Nios in Qsys and change the Hardware multiplication type to Logic Elements or None
the smallest CIVGX doesn't have hardware multiplier blocks for some reason
I changed the Hardware multiplication type to Logic Elements, and I got this error:
Error: Selected device has 60 RAM location(s) of type M9K. However, the current design needs more than 60 to successfully fit Info: List of RAM cells constrained to M9K locations Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_en" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_err" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet:altera_ethernet|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_en" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_err" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data" Info: Node "tse_ref_design:tse_ref_design_inst|tse_ref_design_altera_ethernet_1:altera_ethernet_1|altera_tse_mac_pcs_pma_gige:altera_tse_mac_pcs_pma_gige_inst|altera_tse_mac_pcs_pma_strx_gx_ena:altera_tse_mac_pcs_pma_strx_gx_ena_inst|altera_tse_top_1000_base_x_strx_gx:top_1000_base_x_strx_gx_inst|altera_tse_top_sgmii_strx_gx:U_SGMII|altera_tse_top_tx_converter:U_TXCV|altera_tse_tx_converter:U_TXCV|pcs_data"
:D
Seems like it's too small for the multipliers to be embedded in memory blocks :)
i don't think the two problems are related, you've moved past the multiplier problem to an on chip RAM problem. you can see the hierarchy path is different
i don't know a lot about the TSE Ethernet core, but i would open it up and try and decrease the buffer sizes to use less on chip RAM
as you can see, the CIVGX15 is a very small device
