hello every one
Im using FPGA for the first time using DE0 board cyclone 3 , I need to implement ethernet and many other things i tried to search but found almost nothing using SOPC builder 9.1 Interface Protocols -> Ethernet -> LAN91C111 interface i got this error : it must be connected to an Avalon MM tristate master which is not found in my component list i got instead Altera Avalon MM tristate master BFM when i try to use , it makes more errors but not resolving the main error above im sure im making mistakes but i know no one who can help hope that you could waiting for your replies thanks in advanceLink Copied
