21607 Discussions
Ethernet not work with Linux on HPS
hello,
I copied the files from rocketboards to the sd card and configure all of the switchs and jumpers. My linux boot but I never succeeded to connect the board on the network to test the web application. If I tried an "ifconfig" the eth0 is not here, I have only the lo (loop back). See attached for the boot sequence : (I underline the 2 important mesage)
thanks
I think you'd better login first, then set the passwd. After that ,maybe you can use "ifconfig"
First console Eth-error is before login ask!
In my kit output to RS, its there:
libphy: stmmac: probed eth0: PHY ID 00221611 at 4 IRQ 0 (stmmac-0:04) active Initializing USB Mass Storage driver...
I don't replace original contents of SD-card, may send my files to e-mail, only not fast.
These files is all visible if insert SD-card in PC through adapter, included with kit:
soc_system.rbf 6843 K 05.11.13 01:05 socfpga.dtb 18049 05.11.13 01:05 u-boot.scr 200 05.11.13 01:05 zImage 3128 K 05.11.13 01:05
May be incompatible version of device tree on rocketboards, need be ask there.
Or if Eth-interface disabled through jumpers ?
Or power/ground pin isolated ? Press to Eth-Phy, run test soft from Altera...
On rocket available previous versions of Linux boot image ? There permanently changes its project...
Lanix, please, big console output surround with brackets: "[ code ]" and "[ /code ]" (withoot blanc spaces, its for nonwork inserting)!
Or: analogical with "quote.
Or may include this as separate file.
Could be the wrong pre-loader being used, and it is not enabling the EMAC I/O pins in the HPS, hence the error message about no PHY being found.
Andrew
