21602 Discussions
Exit code = 11... Device verify failure
I use Jam STAPL Player Version 2.5 to implement CPLD upgrade.
But the program return "Exit code = 11... Device verify failure"
1. My system is ARM cpu on Embedded Linux.
2. I only change jam_jtag_io() to map our JTAG port.
3. The TCK click work about 5KHz
Suspicion:
1. The porgram can detect IC. I think that TCK, TDI and TDO are correct.
2. I use Quartus II program CPLD and then use Jam STAPL Player to do only verify action. The result is pass. Base on this experiment, the Jam STAPL Player verify function is correct.
So, The TCK, TDI and TDO are correct and verify function is correct. May the program is bad. But I do know how to debug the program function.
Below is my program message:
C:\jam.exe -aprogram 001.jam -v
Jam STAPL Player Version 2.5 (20040526)
Copyright (C) 1997-2004 Altera Corporation
CRC matched: CRC value = 75D4
Export: key = "JAM_STATEMENT_BUFFER_SIZE", value = 3088
NOTE "CREATOR" = "QUARTUS II JAM COMPOSER 9.0"
NOTE "DATE" = "2010/03/26"
NOTE "DEVICE" = "EPM240"
NOTE "FILE" = "data_sw_0204b.pof"
NOTE "TARGET" = "1"
NOTE "IDCODE" = "020A10DD"
NOTE "USERCODE" = "FFFFFFFF"
NOTE "CHECKSUM" = "0016738E"
NOTE "SAVE_DATA" = "DEVICE_DATA"
NOTE "SAVE_DATA_VARIABLES" = "V0, A12, A13, A25, A43, A92, A94, A95, A99, A100, A105, A109, A111"
NOTE "STAPL_VERSION" = "JESD71"
NOTE "JAM_VERSION" = "2.0"
NOTE "ALG_VERSION" = "51"
Device# 1 Silicon ID is ALTERA04(00)
erasing MAXII device(s)...
erasing MAXII UFM block...
erasing MAXII CFM block...
programming CFM block...
programming UFM block...
verifying CFM block...
Who can help me?:confused:
Hello Pandaliu,
i have the same problem with the same PLD device and ARM as host. Did you have any new infos for that?
Thomas
Hi Thomas
We fixed this probleam. Please fine turn one_ms_delay parameter.
The TCK bit clock must below 1MHz.
one_ms_delay /= DELAY_SAMPLES; <-- Please modify it
Panda
Hi Panda,
thanks for your answer. I thought i has adjust this parameter exactly, but i measure it again and found that the timing wasn't excat enough, because the function do_wait_microseconds is called with values over 500.000!
Now it works fine!
Best regards
Thomas
