I am simulating a circuit that uses the FFT Megacore function. When the simulatoin is functional, it works fine. However, it only produces the first output (which is correct) when tested using the Timing mode. All the other outputs are 0. I have checked the input and it seems like the input is being fed into the block correctly. The design also compiles without any critical warnings on timing. Does anyone have any idea? Any feedback is appreciated.Link Copied
