21615 Discussions
FIR II MegaCore strange output
I generated a FIR Megacore from the IP catalog, and ran the generated simulation script to check its functionality.
Here is what I got:
http://www.alteraforum.com/forum/attachment.php?attachmentid=10242&stc=1
Well, it looks very similar to the impulse response, but I noticed breaks between samples...
when I changed back to binary representation I got this:
http://www.alteraforum.com/forum/attachment.php?attachmentid=10243&stc=1
There are zeros in-between samples!
Can you explain this whether it is normal behavior or wrong usage (bearing in mind that I didn't change anything... it's the original script and testbench)
have you considered valid out signal?
--- Quote Start ---
--- Quote End ---
Sir... you have no idea how much I appreciate you! Probably you've ended my one week pain! :D
And as you say in kurdish... Sarsarim ;)
https://www.alteraforum.com/forum/attachment.php?attachmentid=10244
Bijit Kurd o Arab
