21611 Discussions
FPGA Configuration using CPLD!
Hi all,
I have a question need your precious comments.
As I create my pcb with a Arria and MAXII. I planned to use Paralle Flash Loader in CPLD to configurate Arria.
After following AN386, I successfully download and write FPGA image to a CFI flash.
I use NIOSII IDE to programming and NIOSII command shell to read back. The data existed in flash.
After power cycle, the CPLD should start to move data from flash to FPGA but it's not working.
The input clock to PFL is 27MHz as attached qar.
I measure the address pin, there's 2 high level during flash OE period :confused:.
I wonder any one ever using this function and provide me your experience on that.
Thank you!
BRs,
Johnson
What type of flash memory are you using? I had trouble with S29GLxxxP.
Hi Gee,
Thanks for replying my problem.
I am using S29GL512P10xxx.
The same as yours.
I also connect that A0 pin to another CPLD pin to measure output pattern.
The same pattern as I posted.
BR,
Johnson
Hi Johnson,
The S29GLxxxP needs reset before starting access, and time from power-on or reset to 1st access is longer than previous model. I recommend you to make sure that reset signal is connected to the S29GLxxxp and put a counter in the MAX II so that PFL delays first access.
Thanks!
Hi Gee,
Thanks for your comments.
I will try your suggestion later.
And I want to share you how I download my FPGA image to flash.
I used to use this PFL function as described in AN478 in Arria. But it failed writing to flash and I don't know why at that time.
Later I use CFI interface after initiate a NIOSII and download it using NIOSII EDS and it works.
I also read that data using NIOSII command shell and measure the address pattern.
Through that I found the output of PFL is not correct for flash to work properly.
I will repeat my test on PFL using Arria.
Thanks for your reply.
BRs,
Johnson
Did you write the configuration data and the options bits to flash using the NIOSII EDS? Are the options bits at the location that the PFL in the CPLD is looking for them? I just had an issue where I had the PFL core looking at the wrong location in flash for the options bits. Reran the megawizard and reprogrammed flash and it worked great.
As gee said, you need to write a small power-on reset in the cpld design to hold the flash chip in reset for a bit(whatever the data sheet shows). We ran into this when switching from the N part to the P part.
Hi gmpstr,
Thanks for sharing.
I already added that in my current design.
Yes, I could noticed that there are some data moving out from flash to fpga.
But the complete configuration cycle was not finished, I could see nStatus and nCONFIG from Arria pulling high and low to indicate the data has error.
I noticed that the A0 output from MAXII to flash has a 40-ns pulse...as I posted in my previous post.
Anyway I have a improvement from your inputs, thanks a lot!
BRs,
Johnson
I try to simulate your design. First the PFL access address 0x20040, where pof version locates, then the address points 0x20041 but it means nothing.
If you have modeslsim-AE verilog licence, I will upload the testbench.
Hi Gee,
Thanks for your information regarding simulation.
I measure the output pattern of nStatus and A0 and noticed that the 40-ns glitch happened during nSTATUS is low.
Perhaps I have to double check my settings as I tie all PGM pins to GND..
I saw your simulation output, thanks for your data..
That would be of great help if you could provide me your testbench.
BRs,
Johnson
Hi Johnson,
Looking from the simulation result, 40 ns(1 clock) glitch is normal behavior. If you are concerned about PGM pin, please make sure that they are connected directry, without through resister, to GND.
Regards!
Hi Gee,
You are right that I could see that in scope and wave form design in Quartus.
Do you have any idea about FPP with decompression local or remote/
I don't know exactly how to set my device in which mode.
And I wonder how PFL load configuration data to FPGA and tell decompression is necessary or not?
Thanks very much for your input on this topic.
BRs,
Johnson
Hi Johnson,
The remote system upgrade settings enables state machine in the Arria to control retrying configuration. If you choose FPP w/ decompression setting, you should set appropriate option when creating POF file. The PFL and Arria know whether the data is compressed or not from the POF format.
To create decompressed POF, you should check the compress button which appears pressing property.
Hi Gee,
Thanks for your file.
I have seen this and settings in my project. I just could not make sure if the Arria and PFL function could really implement this during configuration as I haven't seen this setting in PFL megafunction instintiation steps. Instead there's only a FPP or PS selection.
I also ask for cource code for this FPP... as I might need to change some settings like for PGM.
If you know where I could find information about PFL, please let me know..
Thanks so much for your help on this.
Johnson
Hi Johnson,
Are you using FPP with decompression mode? If so, MSEL(3:0) should be set "1011" which makes Arria to know receiving data compressed. The compress option should be set when generating POF, which generate compressed POF. There is a flag to show data is compressed in the POF, so the PFL knows it and send data in every four dclk.
You can find the PFL source code in C:\altera\81\quartus\libraries\megafunctions folder, but unfortunately Altera doesn't disclose the details on how PFL works.
Hi Gee,
I made some measurement and found the Configuration process was stopped after 800us.
I have no idea about what might happen during Configuration as smaller project is ok and the same sof could download via JTAG and function properly.
Any comments on this?
Johnson
Take a look at this document:
http://www.altera.com/literature/hb/agx/agx_52011.pdf
Any chance the pull-up on conf_done or nStatus is missing?
Posting the .cof file and the PFL megawizard generated .v or .vhd file might provide some clues. What is MSEL(3:0) set too? Is the .sof file you are using have compression enabled(see figure 11.1 of above document)?
If you are using compression, read pages 11-5 and 11-6.
Hi Johnson,
Do you mean PFL loads data successfully with one data and fails another?
Would you upload PFL design that you put counter to delay starting PFL? I will check it anyway.
