21607 Discussions
FPGA Counter Catch Eight game(error 10476, error 10558)
hi,
im new to VHDL coding as im still learning the basics, i need to design a counter catch eight game and i have done the code but it shows and error and i am not able to solve it. it will be very helpful if anyone can help me wit this codes
http://www.alteraforum.com/forum/attachment.php?attachmentid=12644&stc=1
the error is shown in the picture.....
The 3rd port of your 'Counter' module is an 'unsigned' signal type and you're trying to connect 'clock_output', a 'std_logic' signal to it.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
hi mr alex,
if i send u my full code will be able to able to fix it for me because as i know i already the sign these signals in the counter. Are u able to help pls?? if can pls drop me ur email, i'll send u my full code in notepad :)
You can attach any code to this post - I suggest the code for your 'Counter' module.
Cheers,
Alex
--- Quote Start ---
Cheers,
Alex
--- Quote End ---
---counter
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity Counter is
port(
CLK: in std_logic;
RST: in std_logic;
Digit1_Output: out unsigned(3 downto 0)
end Counter;
architecture Counter_arch of Counter is
signal Digit1: unsigned(3 downto 0);
begin
process(CLK,RST)
begin
if RST = '0' then
Digit1 <= (others=>'0');
elsif rising_edge(CLK)then
if Digit1 < 9 then
Digit1 <= Digit1 + 1;
else
end if;
end if;
end process;
Digit1_Output <= Digit1;
end Counter_arch;
So, 'Digit1_Output' is a 4-bit value. Which bit of that are you trying to connect your std_logic 'clock_output' to?
I suggest you change
to
Digit1_Output: out std_logic_vector(3 downto 0)
At the top level connect a new 4-bit std_logic_vector signal in place of 'clock_output' and then connect 'clock_output' to whichever bit of 'Digit1_Output' you need.
Cheers,
Alex
