Programmable Devices
20778 Discussions
FPGA Impementation Digital Clock
I need to design digital clock allow global reset and allow user to adjust min and hour.I have done the min and second from 0 to 59 but i having a problem to design a counter 0 to 23.
This is the VHDL that i write but i dunno why my counter 0 to 23 1 times only...after 1 times run finish it will straight away jump to 11 until 23....
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.std_logic_unsigned.all;
entity counter0_to_23 is
port( CLK,Reset,E: in std_logic;
Q_MSB : buffer std_logic_vector (3 downto 0);
Q_LSB : buffer std_logic_vector (3 downto 0));
end counter0_to_23;
architecture structural of counter0_to_23 is
component or_4 is
port( in1,in2,in3,in4: in std_logic;
out1 : out std_logic);
end component;
component not_1 is
port( in1: in std_logic;
out1: out std_logic);
end component;
component or_2 is
port ( in1,in2: in std_logic;
end component;
component and_8 is
port (in1,in2,in3,in4,in5,in6,in7,in8: IN STD_LOGIC;
out1 : OUT STD_LOGIC);
end component;
component decade_counter is
port (CLK,Reset,E :in std_logic;
Q :out std_logic_vector(3 downto 0));
end component;
signal or_out : std_logic_vector(1 downto 0);
signal not_out: std_logic_vector(6 downto 0);
signal and_out: std_logic;
begin
U1: decade_counter port map (CLK,or_out(0),E,Q_LSB(3 downto 0));
U2: not_1 port map (Q_LSB(0),not_out(1));
U3: not_1 port map (Q_LSB(1),not_out(2));
U4: not_1 port map (Q_LSB(3),not_out(3));
U5: not_1 port map (Q_MSB(0),not_out(4));
U6: not_1 port map (Q_MSB(2),not_out(5));
U7: not_1 port map (Q_MSB(3),not_out(6));
U8: and_8 port map (not_out(1),not_out(2),not_out(3),not_out(4),not_out(5),not_out(6),Q_LSB(2),Q_MSB(1),and_out);
U9: or_2 port map (Reset,and_out,or_out(0));
U10: or_4 port map (Q_LSB(0),Q_LSB(1),Q_LSB(2),Q_LSB(3),or_out(1));
U11: not_1 port map (or_out(1),not_out(0));
U12: decade_counter port map (not_out(0),or_out(0),E,Q_MSB(3 downto 0));
end structural;
What you have done isnt really VHDL - you've just created a netlist of components. You can do much better looking stuff in vhdl like this:
signal minute : integer range 0 to 59; signal hour : integer range 0 to 23; process(clk) begin if rising_edge(clk) then if progress_minute then if minute = 59 then minute <= 0; if hour = 23 then hour <= 0; else hour <= hour + 1; end if; else minute <= minute + 1; end if; end if; end if; end process;
thk for your answer...
if using the structural how should i write it....
--- Quote Start ---
--- Quote End ---
Thank for your reply...
If i want to design by using structural how should i write???
