I need to design digital clock allow global reset and allow user to adjust min and hour.I have done the min and second from 0 to 59 but i having a problem to design a counter 0 to 23. This is the VHDL that i write but i dunno why my counter 0 to 23 1 times only...after 1 times run finish it will straight away jump to 11 until 23.... LIBRARY ieee; USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; entity counter0_to_23 is port( CLK,Reset,E: in std_logic; Q_MSB : buffer std_logic_vector (3 downto 0); Q_LSB : buffer std_logic_vector (3 downto 0)); end counter0_to_23; architecture structural of counter0_to_23 is component or_4 is port( in1,in2,in3,in4: in std_logic; out1 : out std_logic); end component; component not_1 is port( in1: in std_logic; out1: out std_logic); end component; component or_2 is port ( in1,in2: in std_logic; out1 : out std_logic); end component; component and_8 is port (in1,in2,in3,in4,in5,in6,in7,in8: IN STD_LOGIC; out1 : OUT STD_LOGIC); end component; component decade_counter is port (CLK,Reset,E :in std_logic; Q :out std_logic_vector(3 downto 0)); end component; signal or_out : std_logic_vector(1 downto 0); signal not_out: std_logic_vector(6 downto 0); signal and_out: std_logic; begin U1: decade_counter port map (CLK,or_out(0),E,Q_LSB(3 downto 0)); U2: not_1 port map (Q_LSB(0),not_out(1)); U3: not_1 port map (Q_LSB(1),not_out(2)); U4: not_1 port map (Q_LSB(3),not_out(3)); U5: not_1 port map (Q_MSB(0),not_out(4)); U6: not_1 port map (Q_MSB(2),not_out(5)); U7: not_1 port map (Q_MSB(3),not_out(6)); U8: and_8 port map (not_out(1),not_out(2),not_out(3),not_out(4),not_out(5),not_out(6),Q_LSB(2),Q_MSB(1),and_out); U9: or_2 port map (Reset,and_out,or_out(0)); U10: or_4 port map (Q_LSB(0),Q_LSB(1),Q_LSB(2),Q_LSB(3),or_out(1)); U11: not_1 port map (or_out(1),not_out(0)); U12: decade_counter port map (not_out(0),or_out(0),E,Q_MSB(3 downto 0)); end structural;Link Copied
What you have done isnt really VHDL - you've just created a netlist of components. You can do much better looking stuff in vhdl like this:
signal minute : integer range 0 to 59;
signal hour : integer range 0 to 23;
process(clk)
begin
if rising_edge(clk) then
if progress_minute then
if minute = 59 then
minute <= 0;
if hour = 23 then
hour <= 0;
else
hour <= hour + 1;
end if;
else
minute <= minute + 1;
end if;
end if;
end if;
end process;
thk for your answer...
if using the structural how should i write it....- Mark as New
--- Quote Start --- What you have done isnt really VHDL - you've just created a netlist of components. You can do much better looking stuff in vhdl like this:
process(clk)
begin
if minute = 59 then
minute <= 0;
if hour = 23 then
hour <= 0;
else
hour <= hour + 1;
end if;
else
end if;
end if;
end if;
end process;
--- Quote End --- Thank for your reply... If i want to design by using structural how should i write???
