21588 Discussions
FPGA crash image in EPCQ256
Terikoska
He wants to run Cyclone V on board with EPCQ256. It would be good if I had an emergency image, as well as an application image on EPCQ256. I read about it on the forum but I'm not sure if I understand correctly that I should configure this EPCQ256 for 3-byte addressing, but Quartus configures it to 4-byte addressing.
How should I use the Crash Image? Is it possible at all? greetings
NurAiman_M_Intel
Thank you for contacting Intel community.
Which forum post were you referring to?
I am not sure what do you mean by emergency image or crash image. But for more information on EPCQ256, you can refer to the datasheet below. It also address about the addressing mode.
EPCQ device datasheet
Aiman
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
