21610 Discussions
FPGA doesn't run after pof file programming.
EEren
The chip - MAX10M50SAE144. When I program sof file - it runs OK. When I program pof file - it doesn't run.
nCONFIG - pull-up, CONFIG_SEL - pull-down, CONFIG_DONE - pull-up.
What could be a problem?
Fakhrul
Hi EEren,
I wish to follow up with you on this case. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
Fakhrul
Farabi
Do you have scope shot for below signals:
  1. nCONFIG
  2. nSTATUS
  3. CONF_DONE
  4. VCC, VCCA, VCCIO
How did you generate the .pof? Can you make sure the Quartus version is same?
regards,
Farabi
EEren
Thank you. The problem was a missing pull-up on nSTATUS.
Fakhrul
Hi EEren,
Fakhrul
EEren
