21600 Discussions
FPGA to SDRAM port access problem
I have a data file that is read by the HPS... I'm assuming the data block is stored in the SDRAM. This is the C code I used:
volatile char *address_pointer = (char*)malloc(bufflength1); //bufflength1 is length of datablock. Approx< 65k.
n=fread(address_pointer,bufflength1,1,f);
When I debug, address_pointer = 0x043CB178
This is the same address I tell the master to start reading the data from...
I want the FPGA to read this data block and process it (and eventually return results to the HPS).
I implemented FPGA-SDRAM Avalon-MM port in the HPS. There is a read master (fft_memory in Fig 1) that connects to the fpga-sdram slave.
The master however fails to read data as the master_wait_request is always high.
Is there something else I need to set/reset before trying to use the SDRAM from the FPGA end??
or is there any other concept like base addresses/ offset that I need to take into consideration?
Any help is appreciated!!
Hello surabhisgp,
i have a similar problem accessing the HPS sdram from NIOS II (http://www.alteraforum.com/forum/showthread.php?t=50754).
Did you find a solution?
Thanks in advance, Patrick
Pls both build up a new Preloader (SPL) and then free the bridges in uboot with the correct fpga2sdram_handoff
i will post my results in http://www.alteraforum.com/forum/showthread.php?t=50754
Patrick
Hello Patrick,
No I didn't find a way around it.
Like others suggested, I did also build the preloader using bsp editor but not too sure what 'free the bridges' means.
Anyway, I abandoned the board after a while and went back to using a cyclone 4.
Surabhi
