FPGAs
I'm trying to learn FPGAs any takers??
what are you trying to learn - and what problems are you having?
I want to save about 40000 bits out of a bit stream over about 1 second of time (coming out of a GPS module), but I don't know how. I would try to use a serial memory chip, but am unfamiliar with microcontroller to memory chip interfacing. I guess I was sort of thinking that an FPGA could act as a memory chip???
If I configure an FPGA to have like 40000 to 50000 OR gates, and individually signal each individual or gate such that it acts like a memory bit location?????
I really don't understand FPGAs or the development environments or anything like that. I'm interested in doing this from a 'low end' standpoint.
There are a lot of FPGAs.
Some have a plenty of internal memory. Of course you can use internal logic cells as registers for memory but this is not the best use. You should use internal dedicated memory blocks.
I'm trying to use an Arduino board, and want to sample the GPS Module bitstream (with a baud of 4800 bits per second) at an interval of like 20us per sample.
I wonder how much I'm going to outlay in trying to configure an FPGA such that it will receive all 40000 to 50000 samples from the Arduino/GPS setup. Does a person need an IDE to work with FPGAs ??? How much do FPGAs cost, how much does an IDE cost?????
The IDE is called Quartus II and is free. See www.altera.com
The FPGAs are kind of expensive 5 to 30 dollars for the application that you talked about.
They are programmed in Verilog or VHDL. Use google to find out more.
--- Quote Start ---
The IDE is called Quartus II and is free. See www.altera.com (http://www.altera.com
--- Quote End ---
The free version only supports the low end devices, which will probably suit this application. You can get starter development boards for a few hundred dollars. Low end altera parts may be individually $5-50, but then you have to cost in all the extra parts and cost of developing your own board.
Somewhere, I thoght I read that the Cyclone ll development board would be good. Is that variation becoming sort of obsolete, or is it still seeing a considerable amount of use??
I may try to buy a Cyclone lll board in like 6 weeks if that doesn't cost a whole bunch more.
Any suggestions would be helpful.
I only started working with FPGAs about a year and I am still fairly low end. But I have found the Cyclone II a very useful board for implementing my designs, I would definitely recommend it.
You can use a developement board to do what you want, its a comparatively easy task. The Cyclone II can have a NIOS processor in it, but you could do what you want in logic, and there is enough memory in the Cyclone II. Also there are a number of boards with memory attached that you can buy, search for Cyclone II dev boards. They are not too expensive. The Quartus software has quite a steep learning curve but seems to be pretty good. And its free!
