21602 Discussions
Failed Co simulation of a Example HLS design
nikhl
Hi  ,
I am have installed the intel Quartus prime 22.2 development suite in my system and tried to compile and test the HLS counter example design but it fails in the Co-simulation.
i++ counter.cpp  -v   -march=Arria10 -o test-fpga
Target FPGA part name:   10AX115U1F45I1SG
Target FPGA family name: Arria10
Target FPGA speed grade: -1
Analyzing counter.cpp for testbench generation
Creating x86-64 testbench
Analyzing counter.cpp for hardware generation
Verifying version information in the included files.
Expecting version 22.2.0.46.1 for all included files.
Included files passed version check. Checked:  none.
Optimizing component(s) and generating Verilog files
Generating cosimulation support
Generating simulation files for components: count
HLS simulation directory: /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/verification.
HLS Elaborate verification testbench FAILED.
See /home/lsai_nikhil/intelFPGA_pro/22.2/hls/examples/counter/test-fpga.prj/debug.log for details.
Error: Cosim testbench elaboration failed.
Makefile:53: recipe for target 't
I have checked the debug .log ,
Debug log output:
/home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32
# -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32
# [exec] elab
# vsim -dpioutoftheblue 1 -sv_lib /home/lsai_nikhil/intelFPGA_pro/22.2/hls/host/linux64/lib/libhls_cosim_msim32 -L work -L work_lib -L altera_ver -L lpm_ver -L sgate_ver -L altera_mf_ver -L altera_lnsim_v
er -L twentynm_ver -L twentynm_hssi_ver -L twentynm_hip_ver -L altera -L lpm -L sgate -L altera_mf -L altera_lnsim -L twentynm -L twentynm_hssi -L twentynm_hip -L hls_sim_main_dpi_controller_10 -L main_dp
i_controller -L hls_sim_component_dpi_controller_10 -L dpic_count -L avalon_conduit_fanout_10 -L count_cfan -L count_en_cfan -L hls_sim_clock_reset_10 -L clock_reset -L avalon_concatenate_singlebit_condui
ts_10 -L cat_done -L count_internal_10 -L count -L cat_cwfsw -L avalon_split_multibit_conduit_10 -L sp_cstart -L altera_irq_mapper_2000 -L tb tb.tb
# Start time: 10:26:00 on Oct 19,2022
# ** Fatal: ** Fatal: (vsim-3827) Could not compile 'export_tramp.so': cmd = '/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc   -shared -fPIC -m32 -B/usr/lib32  -g  -I. -I"/home/lsai_nikhil/intelFPGA_pro
/19.3/modelsim_ase/include" -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_119
33/linuxpe_gcc-9.3.0/export_tramp.S"'
# (vsim-50) A call to system(/home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/gcc   -shared -fPIC -m32 -B/usr/lib32  -g  -I. -I"/home/lsai_nikhil/intelFPGA_pro/19.3/modelsim_ase/include" -I"/home/lsai_nikhil/
intelFPGA_pro/19.3/modelsim_ase/../oem/include" -o "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.so" "/tmp/lsai_nikhil@server1_dpi_11933/linuxpe_gcc-9.3.0/export_tramp.S" >'/tmp/quest
atmp.j5QHxs' 2>&1) returned error code '1'.
# The logfile contains the following messages:
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: skipping incompatible /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x8
6_64-pc-linux-gnu/9.3.0/libgcc.a when searching for -lgcc
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc
# /home/lsai_nikhil/intelFPGA_pro/22.2/gcc/bin/../lib/gcc/x86_64-pc-linux-gnu/9.3.0/../../../../x86_64-pc-linux-gnu/bin/ld: cannot find -lgcc_s
# collect2: error: ld returned 1 exit status
# No such file or directory. (errno = ENOENT)
# FATAL ERROR while loading design
# ** Error: Error loading design
# Executing ONERROR command at macro ./msim_compile.tcl line 15
# End time: 10:26:15 on Oct 19,2022, Elapsed time: 0:00:15
Can anyone help me to resolve the issue?
@intel
hareesh
pls share your project file
nikhl
Hi @hareesh ,
I am attaching the project file here
hareesh
i am trying to duplicate your issue. pls give me some time.
hareesh
hareesh
any update about?
your problem has solved or not?
nikhl
Hi @hareesh ,
No , the problem has not solved, I think it is because of the missing 32 bit arch libraries. I was unable to find few of the libraries mentioned in getting started guide of intel HLS for my ubuntu 18.04.
Can you suggest where I can get those libraries.
hareesh
please follow bellow attachment for installing the 32 bit libraries.
hareesh
any update?
hareesh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
nikhl
Hi @hareesh ,
I was unable to install i686 arch packages , but installed i386  32 bit packages. Still the testbench elaboration failed.
hareesh
may i know your pc supporting 32 bit or 64 bit os?
nikhl
Hi
My System is x86-64 bit , it supports 64 bit OS .
hareesh
i am also facing problem with my compiler pls give me some time i will give the solution.
Thank you,
hareesh
in my machine it's working fine. no problem. i am trying to duplicate your issue, so i need some information about your os
  1. which os are using
  2. quartus version
and once check HLS compatibility also
The Intel HLS Compiler Pro Edition Version 22.3 is compatible with the following Intel
Quartus Prime software:
• Intel Quartus Prime Pro Edition Version 22.3
• Intel Quartus Prime Pro Edition Version 22.2
• Intel Quartus Prime Pro Edition Version 22.1
• Intel Quartus Prime Pro Edition Version 17.1.1
• Intel Quartus Prime Standard Edition Version 21.1
The Intel HLS Compiler supports only Cyclone® V devices in Intel Quartus Prime
Standard Edition.
Intel Quartus Prime Lite Edition Version 21.1
The Intel HLS Compiler supports only Cyclone V devices in Intel Quartus Prime Lite
Edition .
nikhl
Hi @hareesh ,
I am using Ubuntu 18.04 , Kernel: 4.15.0-162-generic.
Also  I am using the Quartus prime pro 22.2 version.
hareesh
follow the bellow document. execute in that way. and attached  counter example design file try with that.
if you are facing same problem after that please download HLS compiler and install it and try same procedure.
hareesh
did you tried what i shared steps?
please update the status of your issue
nikhl
I tried the above steps, still it shows " HLS Elaborate verification testbench FAILED. "
hareesh
As we discoursed in call please update your simulators and same steps.
hareesh
