Programmable Devices
21608 Discussions
Fast switching signal output
Hi, i'm a student. I'm using Altera De2 Board with Cyclone II and Quartus II tool.
1) In my project i have an output that switch fastly. The output pin don't follow it. In the oscilloscope i don't properly see the real signal .
How can i tell to Quartus that the signal is fast ?
2) Another problem. I have on the board an oscillator at 50 Mhz. I want to multiplicate the frequency without using the PLL (ALTPLL MEGAFUNCTION). Is it possible? Is the clock programmable?
I hope you can help me.
1) how fast is your signal? If you decrease the frequency, do you see it on the oscilloscope?
2) no
1) isn't a Quartus or FPGA problem. 50 MHz is send reliably with any availble FPGA I/O standard.
