21613 Discussions
Feeding an input of a PLL with the output of another PLL - Problem
Hi!
I have the following problem:
I want to use a Cyclone 2C5F256 as a LVDS receiver and transmitter.
The received data comes from a Cyclone 2C35F484 and is then converted into RS485 signals. The transmitted data goes back to the Cyclone 2C35F484 and even comes from RS485 signals.
It´s a kind of Interface Card....
In the Quartus Project I have an ALTLVDS receiver with external ALTPLL and and an ALTLVDS transmitter with external ALTPLL.
The Receiver PLL gets it´s inclock from the LVDS CLOCK (from 2C35 Board).
What I try to do is to feed the Transmitter PLL with the "slow clock" output of the Receiver PLL. I´ll do this to avoid using an extra oscillator on the board.
With this configuration I get the following error message:
Error: Can't fit fan-out of node RECEIVE_PLL:inst1|altpll:altpll_component|_clk1 into a single clock region
On an Eval-Board with EP3C40 it worked well.
Does anyone know how to solve the Problem? Maybe I have to make some kind of assignement (Global Clock) in the Assignment Editor? Is it a constraint of the EP2C5 ?
I would be happy about every comment!
Kind regards
Stefan
It doesn't work. Cyclone II PLLs can only be clocked from one of four dedicated clock inputs, each. But you should be able to use a common PLL for LVDS RX and TX.
