Programmable Devices
21610 討論
File for HiLo external SPI flash burner
MuraliRaj
員工
2,438 檢視
I have an sof and jic file for a CycloneV device with an MX25L12833FM2I SPI-flash.
I need to program the SPI-flash with an external burner (programmer) from HiLo systems.
What is the file I need for this.
I understand I can do the conversion from the sof or jic file from Quartus.
There are several choices like rpd, pof etc.
Which one do I need to create for using an external burner.
0 積分
11 回應
Farabi
員工
2,421 檢視
For secondary programming file, you may want to refer to this link : https://www.intel.com/content/www/us/en/docs/programmable/683039/21-3/secondary-programming-files-programming.html
for 3rd party programmer, normally other users choose .rbf or .rpd files.
regards,
Farabi
Farabi
員工
2,415 檢視
Do you have further request?
regards,
Farabi
MuraliRaj
員工
2,400 檢視
Hi Farabi:
Apologies for late reply.
We are going to try the .rpd file today.
Looks like that is the one to use for active serial.
Will let you know.
Thank you.
Murali
MuraliRaj
員工
2,362 檢視
The .rpd file programmed into the spi-flash with the HiLo programmer but it did not work for the FPGA.
Need to socket the device to try other formats.
Farabi
員工
2,323 檢視
Do you have HiLo programmer link so i can relate? I thought HiLo is a connector for highspeed DDR4/QDR RAM.
link : https://www.isipkg.com/wp-content/uploads/2017/01/ISI_Connector-Overview-HiLo.pdf
regards,
Farabi
MuraliRaj
員工
2,313 檢視
Hi Farabi:
Thanks for the responses.
That was a coincidence for HiLo
We use the HiLo external burner.
Link is https://www.hilosystems.com/en-gb/product/category/4
We have the AL-200 programmer.
Murali
Farabi
員工
2,263 檢視
Hello Murali,
You can try .svf file for programming the FPGA.
link : https://www.intel.com/content/www/us/en/support/programmable/articles/000074568.html
regards,
Farabi
MuraliRaj
員工
2,256 檢視
Hi Farabi:
Not sure why you are asking me to try an .svf file.
The link you added appears to indicate: "In the Quartus Prime software, go to the Tools menu and select JTAG Chain Debugger"
That is *not* what I was trying to do. Not even close actually.
I am trying to use an external programmer - the HiLo standalone programmer.
Not sure if I misunderstood what you mentioned about the .svf file. Did you want me to use that to create another format?
My original question was:
"I need to program the SPI-flash with an external burner (programmer) from HiLo systems.
 What is the file I need for this."
Let me know if you need more clarification.
Maybe I am missing something. Let me know.
Murali
FvM
榮譽貢獻者 II
2,232 檢視
To find out what's wrong with your programming method, I'd read back a flash programmed by JTAG indirect programming method with the external programmer. Possible issues are e.g. reversed bit order.
Farabi
員工
2,229 檢視
Hello Murali,
Agree with FvM, you need to check the flash programmed by the external programmer. We dont have the knowledge on HiLo programmer.
regards,
Farabi
Farabi
員工
2,143 檢視
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
回覆
