21611 Discussions
Flash generated using sof2flash fails to configure fpga
Hi ,
I have Stratix IV development kit ,
I want to load Flash file converted using sof2flash utility.
when i use nios2-flash-programmer it works fine .
but it fails to configure FPGA from flash when i cycle power the board .
Anybody have idea ?
I don't know which EDS version you're using but there's at least a bug in version 9.1. Check these threads:
http://www.alteraforum.com/forum/showthread.php?t=24460
http://www.alteraforum.com/forum/showthread.php?t=22441
I've had the same problem and was able to get it working with EDS 9.1 SP2.
I skipped SP1.
Good luck, Ton
Thanks , but i am currently working with EDS 9.1 SP2 . Is there any PFL or optionbit issue ?
I used sof2flash with the following options:
sof2flash --input=stratix_iv.sof --output=stratix_iv.flash --offset=0xC20000 --pfl --optionbit=0x18000 --programmingmode=FPP
Success, Ton
Thanks Ton,
i successfully flashed .sof using that , actually i was using programmingmode=PS .
But you are flashing the sof using factory default CFI flash map.
when i tried to boot from software flash(elf2flash) it goes to Kernel Panic.
sof2flash -------- as u shown
nios2-flash-programmer --base=0x08000000 <yourfile>_hw.flash
Up to this it works fine , now i am converting linux image,
elf2flash --base=0x0a000000 --end=0x0bffffff --reset=0x0a820000
--input=<yourfile>_sw.elf --output=<yourfile>_sw.flash
--boot=path/boot_loader_cfi.srec
nios2-flash-programmer --base=0x0a000000 <yourfile>_sw.flash
now , i powercycle the board , it boots but comes kernel panic.
And if i want to load my custom sof and linux image without the factory default settings , is it possible ?
when i run nios2-terminal, it shows like this ,
linux/nios ii-mmu
init_bootmem_node(?,0x105a2, 0x10000, 0x18000)
free_bootmem(0x105a2000, 0x7a5e000)
reserve_bootmem(0x105a2000, 0x1000)
built 1 zonelists in zone order, mobility grouping on. total pages: 32512
kernel command line:
pid hash table entries: 512 (order: -1, 2048 bytes)
dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
we have 98304 pages of ram
memory available: 124140k/5767k ram, 0k/0k rom (2077k kernel code, 3690k data)
hierarchical rcu implementation.
nr_irqs:32
calibrating delay loop... 74.75 bogomips (lpj=373760)
mount-cache hash table entries: 512
net: registered protocol family 16
init_bsp(): registering device resources
bio: create slab <bio-0> at 0
------------[ cut here ]------------
warning: at /opt/dipen/nios2-linux/linux_source/linux-2.6/fs/sysfs/dir.c:451 sys
fs_add_one+0xb0/0xe0()
sysfs: cannot create duplicate filename '/class/net/lo/statistics/'
modules linked in:
stack from d7c16d94:
d7c16dd8
d0012548
ffffffef
d7c1e000
d7c5fd74
d0588db4
d00125cc
d0555b18
d7c16dc0
00000001
d00c04f0
d7c1e000
d7c5fd74
fffffff4
d05890b4
0000000e
d0151a9c
d0588f3c
d7c4cdfc
d0588d80
00000000
00000001
d0152330
00000000
d01342e4
d7c16e64
d7c4ce04
00000000
00000000
d0588dc0
d7c4cc00
d7c4cdfc
call trace:
[<d0197cf0>]
[<d0188944>]
[<d0188b3c>]
[<d01830fc>]
[<d01830fc>]
[<d01832e8>]
[<d018338c>]
[<d0000210>]
[<d00b0000>]
[<d0002294>]
[<d000e250>]
[<d00021f8>]
[<d0001074>]
[<d0002288>]
---[ end trace 4eaa2a86a8e2da22 ]---
kernel panic - not syncing: loopback: failed to register netdevice: -17
I can not understand ..why this happen ?
Hi Dipen,
Although I also used the Stratix IV development kit, I didn't use NIOS on it. My last NIOS experience is from some years ago, so I'm afraid I can't help you with the kernel panic problem. Well, at least you've set one step. Maybe for the next one, it's better to make a thread in a NIOS forum. I will follow it with interest.
Good luck, Ton
Thanks Ton . Its better idea to make thread on NIOS forum .
