21602 Discussions
Fpga cyclone v 5cefa9f23i7
DmitriyOrlov
Hi, we have device with 5cefa9f23i7 but it doesn't work under -20 degrees, what should we do with that?
Ash_R_Intel
Did you check the timing report at the required temperature or less than that? Quartus generates timing report for lowest temperature i.e. -40 for industrial temp grade.
If the timing is not met at specified temperature, you might want to fix that first.
