Hi all,
I am trying to access GPIO pins from deo nano board.part number 5CSEMA4U23C6.I have done the following 1. I have used the existing example qsys project where I have selected all the GPIO_0 and GPIO_1 and generated the .vhdl files. 2. then I compiled and generated the .SOF for the required part number.all the GPIO's in the Assignment editor is I/O standard. 3. Then using embedded shell using make and make uboot created the uimage(preloader). 4. I copy paste with already in the SD card which had previous default image.but is the .DTB same across??...do I need to create a new .dtb. 5. I created the .dtb and should I use a standard .v format ??? After all these still I am not able to access my GPIO's..Kindly help me out and let me know where I am wrong Thanks in advance Ravi chandranLink Copied
