21615 Discussions
GPIO pins problem in Cyclone III kit
Dear Guys
I bought an altera cyclone III Fpga kit
and it has 8 GPIO(General Purpose I\O) pins only :(
and we need more GPIO pins
So, Does anyone know how i can get more GPIO pins???
and thank you in advace
Which kit?
it is called
Nios II Embedded Evaluation Kit (NEEK), Cyclone III Edition
As far as I'm aware of, the only GP I/Os of the 3C25 starter board are provided through the HSMC connector, which is interfacing the LCD Multimedia daughtercard in NEEK. So I wonder, which 8 signals you are counting as GPIO with this kit? According to the block diagram, there are none. But may be I missed something?
the demo board has some keys and LEDs , this components' pins may be used as input or output pins.
if you need more pins, you can design a daughter PCB with 180 pins HSMC connector. connect them, then the daughter PCB will extends the GPIO pins number.
--- Quote Start ---
--- Quote End ---
it actually has a debug connector (10 pins) on the LCD Multimedia HSMC board , 2 of them are Vcc and Gnd, so the remaining is 8 pins only :(
@ johnboat
Thank you for your help, but i don't know how to use the HSMC bus, it is connected to the LCD Multimedia HSMC board physically
john is suggesting that you disconnect the LCD daughter board from the C3 board and design a new daugher board with the GPIOs you need.
The HSMC pin out is described by an Altera spec and the Cyclone III starter kit's documentation.
http://www.altera.com/literature/ds/hsmc_spec.pdf
There a couple of boards that may suit you, though.
http://www.bitec-dsp.com/hsmc_proto.html
http://www.nialstewartdevelopments.co.uk/products.htm
@rbugalho and johnboat
thank you for your help
--- Quote Start ---
--- Quote End ---
I don't see any. There's a 10-pin-JTAG connector. It's only purpose is to reprogram the MAX II logic device, if neccessary.
