21615 Discussions
GSRD - Build Yocto Fails
james57
After following the GSRD SD Card Version for H-tile S10
Stratix 10 SoC H-Tile GSRD | Documentation | RocketBoards.org
I have gotten to the step to -
"bitbake image"
The build gets to 97% when it fails saying
"gsrf_soc_fpga/stratix10_gsrd_rootfs/tmp/deploy/images/startix10/devicetree/socfpga_startix10_socdk.dtb No such file or directory"
I was wondering if I have missed a step in the GSRD and need to go back to generate this device tree blob, or if I generate it elsewhere, and place it into the directory.
If I need to externally create it, steps to follow would be amazing.
Jeet14
Can you please try first clean the build project and copy again the linux-socfpga .dtsi file to your yocto project after converting to .dtb.
Tiwari
Jeet14
Please follow the below link for device tree generation for stratix 10.
https://www.rocketboards.org/foswiki/Documentation/HOWTOCreateADevicetreeForStratix10SoC
later, convert the dts file to dtb using the dtc utility.
Tiwari
Jeet14
Let me know if you have any other query on this matter.
Jeetesh
james57
Hi @Jeet14  ,
Thanks for getting back to me.
I followed the link that you suggested. I cloned the "linux-socfpga" github and was able to see the proper files in the specified directories
./arch/arm64/boot/dts/altera/socfpga_stratix10_socdk.dts
and
./arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi
 although now I am a little confused how to structure my files such that "bitbake_image" command is able to see these files so the build can finish.
Does this "linux-socfpga" files that was cloned go "TOP_FOLDER" directory from the GSRD, or does it go in the "gsrd-socfpga" folder cloned from -
langdale https://github.com/altera-opensource/gsrd_socfpga
Please let me know if you understand my question or if I am missing something.
James
james57
Here is a what my terminal says after bitbake image fails
Jeet14
Tiwari
Jeet14
Thanks for marking that problem got resolved now.
With that, I now transition this thread to community support.
Thank you.
Tiwari
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 4/5 survey.
