21587 Discussions
Gates are not appeared in RTL viewer
Hey all,
I wrote the next code:
module increase_duration_1(in, clk, out, reset);
parameter LEN=10;
input in,clk, reset;
output out;
wire [LEN-1:0] or_out,path;
wire rstn;
or U2(or_out[0],path[0],path[1]);
assign out=path[LEN-1];
assign path[0]=in;
not not1(rstn,reset);
genvar i;
generate
for (i=0; i<LEN-1;i=i+1)
begin: shift_reg
dff u( .clk(clk),
.d(path),
.q(path[i+1]),
.clrn(rstn),
.prn(1'b1));
end
endgenerate
generate
for (i=1; i<len-1;i=i+1)
begin: or_connections
or u3 (or_out,or_out[i-1],path[i+1]);
end
endgenerate
endmodule
attached photo shows what I get in RTL viewer. why I don't see logic gates?
what am I doing wrong?
Thanks in advance
The or gates are ignored, because they don't generate any output signal in your design.
Or gates generate or_out[i].
and what is about not gate?
--- Quote Start ---
--- Quote End ---
or_out isn't an output of your design. out is the only one, wired to the DFF chain output.
Thank you very much, now I have OR gates.
What is about the NOT gate. his output is connected to CLRN of DFFs and input to RESET. Why I don't see him?
--- Quote Start ---
--- Quote End ---
Look sharp, it has been simply absorbed by inverting the signal. But this doesn't mean much, because RTL is just a functional circuit. You have to review the synthesiszed netlist to see how the cicruit is implemented in LEs.
