21615 Discussions
Generating a signal with noise
What i am doing is i am trying to do is add random numbers to a signal to find PSD later. I wrote a code for random numbers generator which is working fine shown below:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY random IS ------> Interface
GENERIC (n : INTEGER := 32); -- Input bit width
PORT( clk : IN STD_LOGIC;
random_num : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0)
END random;
ARCHITECTURE Behavioral of random is
BEGIN
PROCESS(clk)
VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0');
VARIABLE temp : STD_LOGIC := '0';
BEGIN
IF(RISING_EDGE(clk)) THEN
temp := rand_temp(n-1) XOR rand_temp(n-2);
rand_temp(n-1 DOWNTO 1) := rand_temp(n-2 DOWNTO 0);
rand_temp(0) := temp;
END IF;
random_num <= rand_temp;
END PROCESS;
END;
After that i tried to add the random signal to a known signal to get a new signal so i can find PSD. I wrote a code for that and i am getting some errors. The code is
PACKAGE n_bit_int IS-- User-defined type
SUBTYPE BITS32 IS INTEGER RANGE -2**32 TO 2**32-1; -- -256 ~255
SUBTYPE BITS33 IS INTEGER RANGE -2**33 TO 2**33-1; -- -512 ~511
END PACKAGE n_bit_int;
LIBRARY WORK;
USE WORK.n_bit_int.ALL;
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
USE IEEE.MATH_REAL.ALL;
ENTITY cumulants IS
x0 : IN BITS32;
x1 : IN BITS32;
x2 : IN BITS32;
x3 : IN BITS32;
y0 : OUT BITS33;
y1 : OUT BITS33;
y2 : OUT BITS33;
y3 : OUT BITS33
END ENTITY cumulants;
ARCHITECTURE Behavioral of cumulants is
COMPONENT random
END COMPONENT random;
BEGIN
PROCESS
VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0);
BEGIN
u1 : PORT MAP ( clk => clk1, random => rand_temp );
y0 <= x0 + rand_temp;
y1 <= x1 + rand_temp;
y2 <= x2 + rand_temp;
y3 <= x3 + rand_temp;
END PROCESS;
END;
The errors are
Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or an identifier ("port" is a reserved keyword), or a sequential statement
Error (10500): VHDL syntax error at cumulants.vhd(49) near text ";"; expecting ":=", or "<="
Please help me. Where am i going wrong.
try this:
u1 : random PORT MAP ( clk => clk1, random => rand_temp );
you forgot the random before the port map.
Is this just for testbench code? VHDL already has a built in random number generator for testbenches.
If you need a random number generator that you can synthesize, then look at this tutorial and code:
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial.pdf
http://www.ovro.caltech.edu/~dwh/correlator/pdf/lfsr_tutorial_src.zip
In the code you have above, it looks like you are using a linear feedback shift register (LFSR) to generate your random noise. An LFSR is used to generate a pseudo-random binary sequence (PRBS), but its only one bit of the LFSR that actually has a random characteristic (that is why PRBS has binary in the name). In the code above, you are using the full LFSR register contents, and these are not random. The tutorial shows how you can create a multi-bit output LFSR/PRBS generator (and provides VHDL code to do so).
Cheers,
Dave
additionally, the cookbook (http://www.altera.com/literature/manual/stx_cookbook.pdf) demonstrates a way to use a ring oscillator to generate randomness
Thanks for that man..
How that was very help full dave..Thanks
Guys i corrected my mistake and here is the code
LIBRARY WORK;
LIBRARY IEEE;
ENTITY cumulants IS
x0 : IN BITS32;
x1 : IN BITS32;
x2 : IN BITS32;
x3 : IN BITS32;
y0 : OUT BITS33;
y1 : OUT BITS33;
y2 : OUT BITS33;
y3 : OUT BITS33
COMPONENT random
BEGIN
PROCESS
BEGIN
u1 : random PORT MAP ( clk => clk, random_num => rand_temp );
END PROCESS;
END;
Now i am getting a new errors
Error (10500): VHDL syntax error at cumulants.vhd(49) near text "PORT"; expecting "(", or "'", or "."
Is there anything i am missing because i don't think i am.
Move u1 out of the process.
Cheers,
Dave
Hi dave thanks for the reply
LIBRARY WORK;
LIBRARY IEEE;
USE IEEE.NUMERIC_STD.ALL;
ENTITY cumulants IS
x0 : IN BITS32;
x1 : IN BITS32;
x2 : IN BITS32;
x3 : IN BITS32;
y0 : OUT BITS33;
y1 : OUT BITS33;
y2 : OUT BITS33;
y3 : OUT BITS33
COMPONENT random
SIGNAL s : INTEGER;
BEGIN
PROCESS
BEGIN
s <= CONV_INTEGER(rand_temp);
y0 <= x0 + s;
y1 <= x1 + s;
y2 <= x2 + s;
y3 <= x3 + s;
END PROCESS;
END;
I am getting an error as
Error (10482): VHDL error at cumulants.vhd(49): object "CONV_INTEGER" is used but not declared
is my deceleration of conversation bad? can you suggest me how i can improve my vhdl skills??
--:) ADI
You need to find yourself a good VHDL book.
Your code does not need the keywords 'PROCESS', 'BEGIN', 'END PROCESS', since you have not created any code that needs to go in the process.
For type conversion, you need to look at what the numeric_std library provides. Hint: to_integer, but it takes an unsigned, so you need to figure out how a std_logic_vector gets converted to unsigned, and then convert unsigned to integer. Your code will look like
s <= to_integer(<something here>(rand_temp));
I don't want to spoil your chance to learn by giving you all the details, so please search around and try to figure it out.
Cheers,
Dave
Hi dave
Thanks for the advice. I worked on the code and the output i am expecting is sum on input and random noise but i am getting what ever input i give as output. Here is the code
LIBRARY IEEE;
ENTITY cumulants IS
x : IN STD_LOGIC_VECTOR (n-1 DOWNTO 0);
y : OUT STD_LOGIC_VECTOR (n-1 DOWNTO 0)
COMPONENT random
SHARED VARIABLE rand_temp1 : STD_LOGIC_VECTOR(n-1 DOWNTO 0);
SIGNAL s : INTEGER;
BEGIN
u1 : random PORT MAP ( clk => clk, random_num => rand_temp1 );
PROCESS(clk)
BEGIN
y <= x OR rand_temp1 ;
END IF;
END PROCESS;
END;
The code for random number is shown above any help would be appreciated
Aditya
Hi dave
I think i got where i went wrong..if i have any problem i ll ask for you help. thanks
Aditya...:)
Hi DAVE
I am trying to find the mean and variance for random generating function code shown below. I know how to calculate practically but not able to implement it can you please help me..
LIBRARY IEEE;
USE IEEE.STD_LOGIC_SIGNED.ALL;
GENERIC (n : INTEGER := 16); -- Input bit width
random_num : OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0);
random_sum: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0)
END random;
BEGIN
PROCESS(clk)
VARIABLE sum : STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0');
BEGIN
sum := sum + rand_temp;
END IF;
random_sum <= sum;
END PROCESS;
END;
--ADI
--- Quote Start ---
--- Quote End ---
The implementation depends on what you really want.
For example, if you want the mean and RMS as a function of time, then you can implement a digital filter. The mean is the DC component, so if you have an update rate requirement of several seconds, then that specifies your sample rate, and hence the bandwidth of your digital filter.
Alternatively, you can implement the averaging in software.
Before diving into an FPGA implementation, you need to determine whether that is the appropriate solution, and whether the whole solution needs to be implemented in an FPGA, or whether there is some FPGA and some processor partitioning that would make more sense.
Cheers,
Dave
the random function i generated is w(n) right with so the mean is 1/n(summation of w(n) from 0 to n) and variance is 1/n-1(summation of w(n) square from 0 to n). So how can i implement the averaging in software or in digital filter?? can you please elaborate??
--ADI
What i am trying to to do is to generate auto regressive process.
_adi
--- Quote Start ---
--- Quote End ---
Look at the moving average filter figure on slide 115.
http://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-100slides_hawkins.pdf
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
I have not designed this type of system before, however, briefly reading this entry
http://en.wikipedia.org/wiki/autoregressive_model
It might be possible to implement this type of system using an Infinite Impulse Response (IIR) filter.
You'll have to do a little more research to see if that is true.
Cheers,
Dave
Hi dave i implemented division in my code but its not working as it must can you tell me if my implementation is correct or not
LIBRARY IEEE;
--USE IEEE.NUMERIC_BIT.ALL;
--USE IEEE.STD_LOGIC_UNSIGNED.ALL;
x : OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0);
random_mean: OUT STD_LOGIC_VECTOR(n-1 DOWNTO 0);
END random;
SHARED VARIABLE sum : STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0');
SHARED VARIABLE rand_temp : STD_LOGIC_VECTOR(n-1 DOWNTO 0) := (n-1 => '1' , OTHERS => '0');
SHARED VARIABLE count,count1: STD_LOGIC_VECTOR(n-1 DOWNTO 0) :=( OTHERS => '0');
SIGNAL adi : STD_LOGIC_VECTOR(n-1 DOWNTO 0);
SIGNAL sita : INTEGER RANGE 0 TO 2**n-1;
SIGNAL count2,sum1 : INTEGER RANGE 0 TO 2**n-1;
BEGIN
PROCESS(clk)
BEGIN
END IF;
END PROCESS;
PROCESS
BEGIN
WAIT UNTIL clk = '1';
count := STD_LOGIC_VECTOR(UNSIGNED(count) + 1);
FOR I IN 0 TO n-1 LOOP
count1(I) := count(n-1-I);
END LOOP;
count2 <= TO_INTEGER( UNSIGNED(count1));
sum1 <= TO_INTEGER(UNSIGNED(sum));
sita <= sum1 / count2;
adi <= STD_LOGIC_VECTOR(TO_UNSIGNED(sita,16));
END PROCESS;
x <= count1;
random_sum <= sum;
random_mean <= adi;
END;
Adi
Can you define "its not working as it must"?
--- Quote Start ---
--- Quote End ---
Hey the division part the output i m getting is wrong...according to calculation it should be some value but after execution there are certain values which are repeating and zeros values are also seen in the division..is it because the division is hard to synthesize i am getting unexpected values???
