21615 Discussions
HELP POF FILE EPM240
leon73
bonjour jais examiner avec jtag ma puce altera max epm240 je lis le pof mes il reste vide j’ais converit en fichier jam et jbc je reprogrammer ma puce avec succes mes mon projet ne fonctione plus aide moi mercis jais perdu tourt mes fichier car jais du formater mon pc quelque chosse ne vas pas dans ces fichier mon adresse email leondevil33@hotmail.com
NurAiman_M_Intel
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
RajashekarK_Intel
We only provide support in English. I have translated your question.
"hello jai examine with jtag my chip altera max epm240 I read the pof my it remains empty I converit in jam file and jbc I reprogram my chip successfully my my project no longer works help me thank you jest lost tourt my file because jais of formatting my pc some chosse does not go in these file my email address leondevil33@hotmail.com"
Does this reflect your question correctly?
Rajashekar
leon73
hello thank you for helping I don't speak English excuse me I'm doing a translation my friends I have no more my programmer with a virgin chip I have my programmer with an altera program my I have no more sof files the pof no longer works with usblaster it programs my I must have made a mistake in the programming I think there is the security bit by mistake or I don't know what I did if I read the pof it is empty I extracted jam and jbc the user code has ffffff I don't understand I lost my original file these a friend who had made my program for altera I don't see it anymore we don't talk anymore so no more help from my friends altera is ordered by an atmega328 bootloader luis I always flash them the original hex my altera I read it with jtag my after programming a blank altera it does not work I realized that it remains empty altera should work to have 32 port io expansion I want help to find how to recover my altera program with jtag because I have detected altera the checksum 038 user code FFFFF look at my rar file I am lost with altera I can no longer do my project with the poster files we can recover or with a parallel program where is the problem with this jam file thank you for your help
 bonjour merci de m’aider Je ne parle pas anglais excusez-moi Je fais une traduction mes amis Je n’ai plus mon programmeur avec une puce vierge J’ai mon programmeur avec un programme altera mon Je n’ai plus de fichiers sof le pof ne fonctionne plus avec usblaster il programme mon J’ai dû faire une erreur dans la programmation Je pense qu’il y a le bit de sécurité par erreur ou je ne sais pas quoi Je L’ai fait si j’ai lu le pof il est vide j’ai extrait Jam et jbc le code utilisateur a ffffff Je ne comprends pas J’ai perdu mon fichier original ces un ami qui avait fait mon programme pour altera Je ne le vois plus nous ne parlons plus donc plus d’aide de mes amis altera est commandé par un chargeur de démarrage atmega328 luis Je les flashe toujours l’hexagone original mon altera Je l’ai lu avec jtag mon après avoir programmé un altera vierge ça ne marche pas Je me suis rendu compte qu’il reste vide altera devrait fonctionner pour avoir 32 ports d’extension d’E/S Je veux de l’aide pour trouver comment récupérer mon programme altera avec jtag parce que j’ai détecté alta la somme de contrôle 038 code utilisateur FFFFF regarder mon fichier rar Je suis perdu avec altera Je ne peux plus faire mon projet avec les fichiers poster que nous pouvons récupérer ou avec un programme parallèle où est le problème avec ce fichier JAM Merci de votre aide
NurAiman_M_Intel
Thank you for contacting Intel community.
-By no more sof file, do you mean you also do not have the original code? You can compile your design again to get the sof file.
-Are you using Quartus?
-Is there any error shown?
Aiman
leon73
merci d’aider mon c pas mois qui a compilé altera et je ne peux plus le contacter commande recompiler avec quartus commande configurer les broches d’altera dire si j’envoie le schéma de mon projet avec atmega328 et vous pouvez me dire commande configurer les broches io et les broches à ne pas utiliser Je ne connais pas le cpld ou pouvez-vous me dire si je peux récupérer mon code avec un débogueur La mémoire UFM contient-elle le code flash avec un spinnaker avec un code Arduino puis-je extraire mon flash m’aider à entendre merci SPI master extern flash extract mi code altera
NurAiman_M_Intel
We are in the middle of checking the information for this case. I will update you by next week.
Aiman
NurAiman_M_Intel
To restore the .pof file, you need to connect the baord with JTAG, open Quartus Programmer tab, and examine to retrieve the pof file.
Aiman
leon73
hello I do exactly as you say and my pof file is empty why exam finished successfully but the pof file is empty command recover the flash of my ch Mo
NurAiman_M_Intel
We have check your .rar file, it has memory in it. However, if you wanted to view or get the design in the .pof, it would not be possible due to security reason.
Aiman
leon73
hello first of all thank you help if there is memory we can recover the code it was me who programmed this altera chip and I included a bit for my code but I knew that it was not impossible for a no one knows the cpld of opening I am not capable and I ask for help it is wrong to recover my code I ask to send my altera chip to a person who can withdraw my code and I pay you because I can no longer program my chip and my atmega328 file which contains the bootloader is no longer of any use to me for my project or to explain it to myself even in private command with an external memory with an spi send my code and recover it these are not a secret of nasa these a simple code for an io port expansion to program it is ordered by atmega328 I still have the original ATmega code help me ois I pay for the time lost to recover my project I leave you my email address leondevil33@hotmail. com because I don't want to send my chip for acid attack for reverse engineering I just want help and I know that I was able to recover my code with another technique in 12c these are possible for professionals I am waiting to hear from you my friends thank you thank you
NurAiman_M_Intel
We apologize as your request are beyond our capabilities. Due to the hardware and software limitations, it is not possible to retrieve the .pof file as per requested.
We apologize for the inconveniences.
Aiman
NurAiman_M_Intel
leon73
thank you for answering my friends I still have the atmega file the atmega328 altera bootloader was lost because each time I placed a security bit in the programming I have to recover the drawing or the source code of altera max epm240 is there someone who can recover my pof file because it remains empty to examine with quartus I repeat jtag is not deactivated I read comes altera with usblaster my remains empty it is false recover code a friend could create a programmable drawing if I post the diagram of my pcb pins use from alera with the connection to atmega if yes I really need it I don't know how to make my pcbs anymore I am ready for compensation debug altera or create a verilog drawing with my schematic if yes I can post it or an email address to arrange with an altera specialist I am here for that thank you
