21611 Discussions
HLS compiled qsys modification and regeneration problem
cosx
Hi everone,
I came across a question about modifying HLS generated qsys and regeneration of the modified system.
My quartus SDK compiler is 15.1.
I compiled a .cl file using command "aoc -s -v  ().cl --board (board_name)".
A qsys named system.qsys had been generated. Next I modified this system by adding some customised components.
After saving ths system, I regenerated this system.qsys into .v file. The command I used for regenerate was
'qsys-generate system.qsys --synthesis=VERILOG --family="CYCLONE V" --simulation=VERILOG'.
After doing this, however, the system.v was not shown in the synthesis folder. Nor was it shown in simulation folder.
Before regeneration, I had already removed all HLS generated system folder and "system.tcl" file. However, the system.v was still not there.
May I ask if the .v file has been hidden or something else happened?
I have also attached the whole project for your references.
Thank you very much!
Mingqiang
cosx
Hi everyone,
A new update here:
when I use aoc -v to compile the project, some strange messages occur:
com.altera.hdlwriter.EntityWritingException: Connection is not connected float_add:avm_local_bb1_ld__inst0 -> ?
at com.altera.hdlwriter.internal.OldEntityWriterInternal.addConnection(OldEntityWriterInternal.java:431)
at com.altera.hdlwriter.internal.OldEntityWriterInternal.writeHDLInternal(OldEntityWriterInternal.java:122)
at com.altera.hdlwriter.internal.EntityWriter.writeHDL(EntityWriter.java:40)
at com.altera.sopc.generator.EnsembleGenerationFileSet2.generate(EnsembleGenerationFileSet2.java:61)
at com.altera.sopc.generator.FileSet2.generate(FileSet2.java:150)
at com.altera.sopc.generator.Sellafield.generate(Sellafield.java:366)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.performGeneration(SbGenerate.java:518)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.act(SbGenerate.java:464)
at com.altera.utilities.AltCmdLineToolBase.runTheTool(AltCmdLineToolBase.java:718)
at com.altera.sopcmodel.sbtools.sbgenerate.SbGenerate.main(SbGenerate.java:965)
May I ask has anyone come across this before?
It seems that my defined IP has problems, but don't know why it has problems..
Thank you again!
Mingqiang
OliverTheEngineer
Hello Cosx,
I'm having exactly the same problem, 4 years later... I have not seen any other occurrences of this error, do you remember if and how you solved it?
Thank you,
Oliver
OliverTheEngineer
It turns out that this error is due to a mistake in the signals on Platform Designer. In my case, I had chosen the wrong size for my APB PSEL signal. I found out by creating an example component with a template APB interface and observing the given signals.
