- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
hi,
I have been thinking of purchasing the sockit (http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&categoryno=167&no=816) board and want to make sure it fits my needs. I can see the Gbit PHY is connected to the HPS. Is it possible to use this PHY from a Nios? thanks!Lien copié
2 Réponses
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
any update on that?...i am planning to purchase Arrow SocKit board and also concerned about accessing peripherals connected to HPS from FPGA side, particularly Gbit PHY. thanks- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
I'm a beginner at this myself, but so far from what I've gathered, you wouldn't want to access the Ethernet PHY from the FPGA side. The Ethernet MAC is a SOC element connected to the ARM cores. The MAC controls the PHY. If you want to send/receive data over Ethernet, you should write FPGA code to place/get your data into memory. You would then trigger an interrupt to the ARM. It then runs the TCP/IP stack. Implementing Ethernet in FPGA code takes a lot of resources. You have a perfectly good Ethernet in the processor side.
Répondre
Options du sujet
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
