Hamming window
Can you please give me suggestion how do I design hamming window with verilog hdl on
DE2 board ???
In terms of Verilog, what you need to implement is a Nth order FIR filter.
The filter's coefficients will be the Hamming window's coefficient.
I am trying to design front end of speech recognition system on FPGA.
I appreciate if you could provide me with useful resources which help me design a hamming window.
Altera provides some filter IP. altera.com/support/examples/verilog/ver-fir-coefficient.html
If you don't have access to the IP then you can build a FIR filter from scratch or get some examples online. Then generate the Hamming Window coefficients. (matlab will do this for you).
Altera has some examples: altera.com/support/examples/exm-list.jsp?cat=dsp_filters_transforms&GSA_pos=4&WT.oss_r=1&WT.oss=FIR%20filter%20example
rbugalho & winfrees,
you suggestions were very useful.
Thank you very much.:)
