HardCopy Chip size
명예로운 기여자 II
1,560 조회수
I have a question about the chip size of hardcopy. In a case of my real gate
count is much less than the usable gate count, is the chip size going to be
smaller as well? Pin count is also much less than the available I/Os. Thank you!
Peter Chang
0 포인트
2 응답
명예로운 기여자 II
727 조회수
--- Quote Start ---
Peter Chang
--- Quote End ---
HardCopy devices have their programmability removed and are available only in certain packages. They die size is maybe smaller due to removed programmability. The number of I/O's depends on the package. As far a I know you can not scale down the number of I/O's.
Kind regard
GPK
0 포인트
명예로운 기여자 II
727 조회수
Hi GPK.
Thanks for your answer. If it is as you said, then the size can't be scaled down too.
It isn't as good as what I expected. Anyway, thanks a lot!
Peter Chang
0 포인트
응답
