Programmable Devices
21615 Discussions
Having a clock issue
Im rather new to quartus and having trouble with one of my assignments.
I am designing a moore counter using 8 states and 3 jkff2 flip flops. Im almost certain that everything is wired up correctly but my simulation only shows the first state and almost seems that the circuit is not running the positive edge clock input.
Im not sure if i have to do anything to set up the clock or if simply creating an input with a controlled waveform is right but for some reason the clock won't shift into the second state.
Any suggestions or help would be greatly appreciated.
Thank you.
Have you got a testbench? why not post the code and the specific problems, maybe showing a waveform that shows the problem. Otherwise, we can only guess.
Hi Eddywick
Please post your sample piece of code about your state transitions so that we can find out why the state is stuck at first state itself
I haven't had to code the assignment yet just using Block Diagram/Schematic File. Attached is the circuit
The picture is too low resolution to reall read it properly. Please re-attach at a higher res.
This might be better
