Programmable Devices
21618 Discussions
Having trouble programming Cyclone V
Hot_Coil
So I've built a custom FPGA development board that basically breaks out all the IO to headers, groups the power into 3 rails driven by an external bench supply and I've adjusted my J-tag wiring to match page 7-35 of the Altera Datasheet CV-52007 for the 5CEBA2F23C8N Cyclone V FPGA I'm using. I've also tried the Passive serial wiring from 7-31 of the same datasheet. (Both configurations I've used the appropriate MSEL connections from another page(s) of the same datasheet.)
Using the most current version of Quartus with a USB Blaster II to try and program the chip in Jtag mode I get a "Error (209040): Can't access JTAG chain" and "Error (209012): Operation failed"
and programming fails. Trying to program in Passive Serial programming mode I get Error (209035): Device chain in use" and "Error (209008): Configuration failed" and programming fails.
I need help troubleshooting this. Presently I'm not sure if this is a hardware issue (bad power supply config, board fabrication issue, USB Blaster II issue, etc), or a software issue in Quartus.
I know my basic VHDL test code is good. I have experience writing VHDL in college and using it on Altera built demonstration boards back then, but this is the first circuit board with an FPGA I've created my self.
I suspect power supply since I can't find a very good datasheet material on the power supply requirements beyond a table of pin voltages. One thing that's made the process of making my own development board tricky is datasheet fragmentation. I haven't been able to find one datasheet with all the info I need but instead find bits and pieces in multiple sheets and not all at the same time or in the same place. A schematic of the power wiring is included below.
Farabi
To make sure your power supply to FPGA meeting the FPGA requirements, could you please check below signals?
1- nCONFIG(active low) - turn low-then-high when FPGA completed power ramp up and start to enter configuration mode
2- nSTATUS(active low) - turn low-then-high when FPGA enters configuration mode.
3- CONF_DONE (active high)- turn high when FPGA completed configuration, and enter user mode.
If you dont see activity of above signals, the power supply is not meeting device requirements.
regards,
Farabi
Farabi
Farabi
Please check your pin connection by referring to pin connection guideline : https://www.intel.com/content/www/us/en/content-details/654351/cyclone-v-gx-gt-e-sx-st-and-se-device-family-pin-connection-guidelines.html
regards,
Farabi
