21587 Discussions
Hello, Is it possible connecting two Cyclone 10 to one virtual component logically by SerDes in order to inlarge the RAM capacity ? Thanks
Toy
a_x_h_75
New Contributor III
It would be considerably cheaper to bolt an external RAM to your primary Cyclone 10 device...
However, if you really want to bolt two Cyclone 10 devices together via SERDES - it's very possible. I'm not sure what you want from a single 'virtual component'. However, there is IP for the SERDES and a relatively small amount of logic each end of the link should suffice.
Cheers,
Alex
Rahul_S_Intel1
Hi ,
You can connect by SERDED but also there is an option to connect throught EMIF IP for external RAM modules.
Rahul S
