21611 Discussions
Hello everyone, I need your help I'm using ADC AD9254 and DAC 5672, with FPGA DE10 standard, I want to acquire data, so Implement this code: the data out is associated to The dac, I get the result below:
JEL_W
LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY Co IS
port (clk:    in std_logic;
   reset:   in std_logic;
   DCO:    in std_logic;
Data_valid: out std_logic;
Data_in:  in std_logic_vector(13 downto 0);
Data_out: out std_logic_vector (13 downto 0)
end;
architecture Co_arch of Co is
signal count : std_logic_vector(13 downto 0);
begin
process(clk,reset)
 begin
 if reset='1' then
   count<= (others=>'Z');
 elsif rising_edge(Clk) then
 if DCO='1' then
 count<=Data_in;
 Data_valid<='1';
 else
 Data_valid<='0';
end if;
end if;
Data_out<= count;
end process;
end Co_arch;
Rahul_S_Intel1
Hi ,
May I know what help you needed
JEL_W
Hi
I sent a sinusoidal signal through low frequency generator to ADC , but I didn't manage to get the same signal at the output of DAC,
I get an inversed signal, the question is how can I obtain the same signal, Did I miss something in the code ?
Thank you
corestar
Is your DAC exepcecting signed or straight binary. Same for the ADC. What you are seeing is almost right and very common when there is a signed unsigned conflict. For example, if your ADC is returning a signed number, but your DAC expects straight binary, but you fail to offset it, you will see something like what you show.
IDeyn
New Contributor III
Hi JEL W,
It looks like you missed a sign, either in code or in DAC or ADC settings, where you probably need to choose two's complement instead of offset binary which is chosen by default.
Ivan
