21615 Discussions
Help me to config ADV7181B with I2C core on DE2 kit
Hi all,
I try using SOPC with Nios II and Microtronix I2C core to configure ADV7181B (video convert IC on DE2 kit) , but it not work.
Could anyone help me to fix this problem. Thanks for reading!
This `s my C code:
# define I2C_BASE 0x00000020# define OUT_LED (unsigned char *) 0x01003000
int i2c_write_adv(unsigned char slave_addr);
void write_byte (unsigned char reg_addr, unsigned char data);
int main()
i2c_write_adv(0x20);
return 1;
int i;
// ADV Address
IOWR_MTX_AVALON_I2C_ADDR(I2C_BASE, slave_addr);
// Start Condition
IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE,MTX_AVALON_I2C_ENABLE | MTX_AVALON_I2C_MASTER_STANDARD | MTX_AVALON_I2C_START );
// Wait for event
while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) );
// Clear interrupt
IOWR_MTX_AVALON_I2C_STATUS(I2C_BASE, 0);
// Check if ADV responded
if (IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_NACK)
printf("ADV not found.\n");
return 0;
write_byte (0x15,0x10);
// Stop Condition
IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE,IORD_MTX_AVALON_I2C_CONTROL(I2C_BASE) | MTX_AVALON_I2C_STOP);
// Wait for event
// Clear interrupt
// Disable
IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE, 0);
return 1;
// write address
IOWR_MTX_AVALON_I2C_DATA(I2C_BASE, reg_addr);
// Wait for event
while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) ) ;
// write a byte(fill transmit buffer)
IOWR_MTX_AVALON_I2C_DATA(I2C_BASE, data);
// Wait for transmit buffer empty
my project is attach
