21615 Discussions
How can I use M9K RAM Memory in CycloneIII ??
Hello Everybody !..
I have seen in CIII datasheet that it has a different kind of RAM block called M9K, with higher frequency.
When I use "reg" is this a M9K??
I Use Verilog, How can i define and use this Memory Block?
A solution without using SOPC builder is preferred.
--- Quote Start ---
Hello Everybody !..
--- Quote End ---
you can do that by using :
reg [0:7] my_ram[0:63] /* synthesis ramstyle = "M9K" */;
But why do you want to specify the RAM implementation ?
Knd regards
GPK
--- Quote Start ---
Knd regards
GPK
--- Quote End ---
i have a solution of my project which has a lot of shift registers and i can have maximum 125 MHz in my algorithm.
I saw that M9K type ram block has a very high frequency and wondered if i can increase my frequency..
--- Quote Start ---
--- Quote End ---
do you have problems to achieve your required clock speed ? Are you shift registers as register implemented ?
Kind regards
GPK
Use the MegaWizard plug-in manager if you want to create a ram-based shift register. It's under the "Memory Compiler" section.
Jake
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Yes, My registers are defined as you mentioned above, like this.
I don't have a trouble of speed, my current solution works fine but it would be fine it it could work faster.
--- Quote Start ---
Jake
--- Quote End ---
thanks jakobjones, this was what i was looking for..
